Renault Megane 1.4 1998 washer
bill hughes
Unread post by bill hughes »
Hi all can anyone please tell me if there is a fuse for the windscreen washer as the handbook shows nothing, if not has anyone changed the motor and is it much of a job, both the windscreen and rear wipers work but neither washer, many thanks for any help.
elma
x 284
Re: Renault Megane 1.4 1998 washer
Unread post by elma »
Renault tend to print on the inside of the fusebox cover a little picture of what each fuse is for.
ekjdm14
x 266
Unread post by ekjdm14 »
If you do end up pulling the pumps out, you may find them full of congealed screenwash if you're lucky & a good rinse out of the washer bottle and clean of the pumps may sort them.
Failing that, I can't imagine them being expensive from a scrapyard and shouldn't be too hard to access. Most of the time you can reach a washer pump from behind the arch liner, just be prepared for a soaking when you remove them if the bottle is full (and if it's fresh screenwash mix, try and catch it, filter out any grot and reuse it)
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
