Gearbox code
Varsi2016
Gearbox code
Unread post by Varsi2016 »
Hi there,please help!!, the gearbox has just died on my 206 and I'm trying to find a replacement but I keep being asked for a code. As the car is locked in the local garage I don't have access till Monday. Can this be done with the reg etc?. Please help.
x 1498
Re: Gearbox code
Hi
Can probably get it if you have got the VIN.
Varsi2016
Re: Gearbox code
Thanks, vin is- VF3**************[VIN obfuscated, can be read by forum staff]
x 1498
Re: Gearbox code
Seems like there are a few marking options! MA box....has the diff failed?
2222 S7
01
NEW MEC GEARBOX
CP(16X65)-CT(19X17)
MARKING CP81 (CP81) CP09 CF09 CP22
2223 HY
RP 2223 WW
EXCHANGE MEC GEARBOX
CP(16X65)
MARKING CF09 CFK9 (CFK9)
Varsi2016
Re: Gearbox code
Thank you very much for your help. Not sure as to what has failed as old box is still on the car. Car still goes but there's a rattle/scraping noise when the car is moving. More so when taking foot off the gas.
ekjdm14
x 269
Re: Gearbox code
Unread post by ekjdm14 »
Sounds like it could be diff bearings possibly, has your garage checked the oil level/condition & what have they based their diagnosis of gearbox failure on? obviously without hearing the noise I can't say for sure, but there's some other things that could cause rattling/scraping like a dying/disintegrating clutch or even just a CV joint being dried up... I'd have to assume the garage know what they're doing though but it's worth double checking before replacing the box I think?
If the gearbox is out of oil then I have heard of them coming back to life with a fresh fill & another change 1500miles down the road although this would be a "discretion call". If there was oil but it came out looking like metallic brown paint then more likely the box is dying.
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
