X7 Remote - Problem
Sloppysod
x 396
X7 Remote - Problem
Unread post by Sloppysod »
Hi All,
I replaced the battery in my remote a couple of weeks ago, I thought it was getting flat because sometimes it would not unlock the car first time. It worked fine for a while but now it is starting to behave the same, is this a sign of my fob circuitry packing up or what, if so can I reprogram another 2nd hand remote with my Diagbox, or will it be a main agent task!? :(
Stu
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6945
Re: X7 Remote - Problem
Over time when the keys are dropped or with constant pressing, it can cause the micro switches to become loose and eventually come away. Have a look when you open the fob to see if the unlock micro switch is loose. I soldered a friends back on after it had completely detached itself - working perfectly now.
I am not sure on the X7 if you can reprogramme a second hand one from another vehicle Stu.
Sloppysod
x 396
Cheers Marc,
Micro-switch(es) are still attached, I took the fob apart and used the buttons direct (fingers) and if I applied pressure to one side of the unlock switch it worked fine, could not find the same sweet-spot on the lock, the lights one is fine, but then again it does not get used that often. I think the switches are past their best and will need replacing. Thanks for you help.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 1940
Unread post by Paul-R »
You could try using some switch cleaner/lubricant on the microswitches first. I used the cleaner/lubricant on the microswitch inside our wireless doorbell switch some years ago and it's still working.
You can get the type which is cleaner only (i.e. no lubricant) but I don't think that would be as good.
Sloppysod
x 396
Thanks Paul, I have some of this stuff and I did think of trying it before replacing the switches, as my soldering circuit-boards with bad eyesight & 'Gorilla' fingers is not easy. [-X
Using my spare at the moment, I think I am lucky to have one.
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
x 6945
You could always try synching the fobs again. Turn ignition on only then hold lock button for 10 seconds.
x 1940
If it sometimes works then surely resynching is not the solution?
x 6945
They can become unsynched at times as the codes are cycled. It's a recommended procedure to do and can be caused when using at long ranges. It's just another suggestion that won't cost anything to try.
x 1940
Quite right!
Sloppysod
x 396
GiveMeABreak wrote:You could always try synching the fobs again. Turn ignition on only then hold lock button for 10 seconds.
If it was un-synced then surely it would not work at all. Nope I think the switches are becoming old and tired, just like me :?
Thanks again
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
