Xantia Cruise Control
DHallworth
x 167
Unread post by DHallworth »
When I converted the Activa to a V6 I toyed with the idea of fitting the cruise control from the V6, unfortunately my car didn't have the loom in place so I didn't bother.
Whilst my interior is stripped out (long story, blog entry coming soon) I've decided I'm going to do it. From memory, I removed the bellows from the throttle body so I'll need to dig them out of the shed, also, from memory, the additional components are:
Brake Switch
Clutch Switch
Master Switch (on dash)
Stalk (on steering column)
Vacuum pump under front wing
Is there anything else that I've missed?
Also, as none of the wiring is present on my car, I'm going to need to wire it in separately, creating the loom as I go. Does anyone have a wiring diagram for the cruise control on the V6? Even better, a wiring diagram for a LHD V6 manual fitted with cruise control from the continent [-o<
Thanks in advance!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 1450
Re: Xantia Cruise Control
Unread post by xantia_v6 »
There is also a Hella cruise ECU and a purple relay. The wiring diagram would be similar to an XM diagram (which I can supply if required).
hattershaun
(Donor 2022)
x 4
Unread post by hattershaun »
David, I've emailed you the 28 page instruction guide that you sent me 4 years ago for fitting cruise to a Peugeot 406. That's still on my list of jobs for tomorrow on my Xantia!
Shaun
C6 3.0 HDi Exclusive - 2010
SM 3.0 - 1972
DS 23 Pallas - 1975
GSA Pallas C-Matic - 1982
x 1999
Unread post by Stickyfinger »
Maybe we shoild all get together at one of the shows and do them all at the same time ? :)
A cruise to a cruise cruise anyone ?
DHallworth
x 167
hattershaun wrote:David, I've emailed you the 28 page instruction guide that you sent me 4 years ago for fitting cruise to a Peugeot 406. That's still on my list of jobs for tomorrow on my Xantia!
Cheers Shaun!
If you're doing it tomorrow, let me know how you get on :lol:
I think yours will be easier then mine as you swapped the entire loom inside the cabin too, didn't you? I've not got any of the plugs on mine for cruise unfortunately.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 1999
David, do you have lots of spare plugs/connectors ?....I have the looms from the v6s2 I scrapped hanging in the shed (some cut off ) some images may help me select some of the correct ones for you if needed.
DHallworth
x 167
Have just emailed you the guide that I sent Shaun all those years ago. I believe the connectors are all pictured in there.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
x 1999
Got it, will check later in the week (off to Falmouth tomorrow) and have to bleed the oil through the Rayburn ...due to being a prick !
