Problem changing down gears ?. C5 2005 1.6Hdi
Rochy101
Unread post by Rochy101 »
First time this yr and sure as eggs are eggs it wont be my last visit this Im sure :rofl2: Happy New yr one and all.
Ok my 2005 C5 1.6Hdi Estate 166k on the clock -New Engine change 60k full service history.
My issue is changing down gears is weird the gear stick very floppy and hard to locate gears from 5-4-3rd and some times a bit clunkey in first as if it slips out of gear before i start off. :oops: . I thought it may be the clutch as it has done about 106k on it . All info welcome and thank you in advance .
Currently driving
2005 C5 Estate 1.6hdi aka "Duggy" rhd
2006 C5 Estate 1.6hdi aka "Cissy" rhd
1990 Ax 1.1 aka "Baggy" Lhd
x 1240
Re: Problem changing down gears ?. C5 2005 1.6Hdi
Unread post by Peter.N. »
If its the clutch dragging it will go into gear OK without the engine running but will be difficult or crunch with it running. Sounds more like the linkage. I had a problem with a 406 that wouldn't always go into reverse which was due to the end of the outer cable having come adrift from the ferrule, I clamped it up with a pair of mole grips and never had any more trouble.
Rochy101
Would that be the linkage on the gear box or under the gear stick ?. thanks for your input .
Currently driving
x 1240
Mine was a the bottom front but don't know if the C5 uses the same gearbox, my 406 was a 2.0.HDi.
