Airbag module location citroen nemo?
Thechemotor
Unread post by Thechemotor »
Bonjour everyone. If someone could tell me where do i start "digging" on my citroen nemo car for the airbag unit as i need to reset it. I have no idea where is the location in this car. Any advice will be more than welcome!.
Sorry if this thread has been made before. Im new in this forum.
x 1342
Re: Airbag module location citroen nemo?
Unread post by xantia_v6 »
Welcome to the forum.
I think it might help if you give us a bit of background information about how you got into the situation where you think that the airbag module needs to be reset. There are probably several airbag modules on the vehicle, which one are you having trouble with?
The main airbag control module is probably under the console below the handbrake handle.
Thechemotor
Hi. Thanks for your reply. I'm fixing a salvage car which only the driver airbag have been deployed. So the warning light on the dash with the message still is on even i fitted a new seat with an un deployed airbag. Im not an expert but i assume that after a crash the airbag control module needs to be cleared about it?.
x 3275
I believe that the airbag ECU will have locked down (so that, if they need to, the Authorities can read it to see what happened). I know that DHallworth repaired a C6 that had been kerbed, and whose airbags had deployed. He sent the ECU off, and the specialists reset it, so that was OK. Here is the thread, and the relevant details start on page 68;
https://www.frenchcarforum.co.uk/forum/ ... start=1005
Thechemotor
Thank for your help ;)
x 1044
Unread post by wheeler »
Im not familiar with the Nemo But pretty much every Citroen I can think of has the main airbag ECU located under the centre console either in front of the gear lever or behind the handbrake.
