C5 Exclusive Badge
hoggers
x 11
C5 Exclusive Badge
Unread post by hoggers »
So, some of you would have noticed the rear of my has no badges. The previous owner took them off and replaced with a [emoji226] which he'd super glued on!!!
After some dental floss it looked like this...
After a lot of nail varnish remover it looks like this...
However, I got impatient with the last bit and did a bit of wet sanding and got carried away and wet through the lacquer [emoji35]
Just above the H
I was thinking of putting on the newer style badge
Anyone know the part number as the lady on parts department was useless. She also told me they don't do the Exclusive rear badges anymore either! Anyone know the part number for this so I can phone other dealers?
Sent from my iPhone using Tapatalk
x 1485
Re: C5 Exclusive Badge
By the looks of it, it came with only chevrons in the centre, C5 and Exclusive to the lower right, Citroen to the lower left. Later cars seem to have moved the Citroen to under the chevrons. Part Nos below. The 'badge' is the C5 and Exclusive at lower right (Excl not available separately). The middle two are the Chevrons. 7810T5 is an earlier part no, the other later - although there appears to be a gap in the dates in service.citroen! not sure if this includes the 'Citroen' - this is available as the last part number (earlier part first, later one afterwards - the later ones has a more 'rounded' letter structure.
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000866628 BADGE 11.89 GBP 14.27 GBP 14.27 GBP
00007810T5 EMBLEM STRIPE 17.17 GBP 20.60 GBP 20.60 GBP
98038106VD EMBLEM STRIPE 22.39 GBP 26.87 GBP 26.87 GBP
00008665YS BADGE 11.63 GBP 13.96 GBP 13.96 GBP
98038118VD BADGE 10.49 GBP 12.59 GBP 12.59 GBP
elma
x 287
Unread post by elma »
Thats made my head spin.
hoggers
x 11
elma wrote:Thats made my head spin.
yeah I've had to read it a few times to get my head round it [emoji23]
hoggers
x 11
RichardW wrote:By the looks of it, it came with only chevrons in the centre, C5 and Exclusive to the lower right, Citroen to the lower left. Later cars seem to have moved the Citroen to under the chevrons. Part Nos below. The 'badge' is the C5 and Exclusive at lower right (Excl not available separately). The middle two are the Chevrons. 7810T5 is an earlier part no, the other later - although there appears to be a gap in the dates in service.citroen! not sure if this includes the 'Citroen' - this is available as the last part number (earlier part first, later one afterwards - the later ones has a more 'rounded' letter structure.
so if iv understood right - to get the badge above you think id need:
x 1485
Yes, that would give you the later chevrons and Citroen badge.
hoggers
x 11
Having a look on eBay and came across this which says it fits my car - part number is different to the one listed above [emoji848]
I've had a look and noticed the new rounded badges are fitted to 2012 onwards when there was a facelift to the front grills and the chevrons on the steering wheel. Not sure my OCD will cope with knowing that - sad I know!
Now thinking of fitting the standard chevron with the sharper font - that said I think the 'Citroen' on the rear of the C5 will be too big to go in the middle. So looking at a the 'Citroen' fitted on the C1
Wow I sound like a nut job [emoji85]
elma
x 287
hoggers wrote: Wow I sound like a nut job [emoji85]
True Citroen driver, it's required.
x 1999
Unread post by Stickyfinger »
Christians will defile anything :)
x 6956
hoggers wrote:Having a look on eBay and came across this which says it fits my car - part number is different to the one listed above [emoji848]
Yes that isn't the original part number they have listed - it's probably for another model altogether - you have to expect that on the bay.
Your original chevrons boot badge is 7810 T5 as Richard has listed.
98038118VD BADGE 10.49 GBP 12.59 GBP 12.59 GBP is the new rear chevrons
Forget the front - bonnet trim - different design.
x 6956
As promised, I've emailed you a full manual for your car (which is the extended version with the Navidrive 3D User instructions too). 315 pages of bedtime reading for you! :-D
hoggers
x 11
Stickyfinger wrote:Christians will defile anything :)
[emoji23]
hoggers
x 11
GiveMeABreak wrote:As promised, I've emailed you a full manual for your car (which is the extended version with the Navidrive 3D User instructions too). 315 pages of bedtime reading for you! :-D
Perfect toilet material [emoji1305]
hoggers
x 11
If this is the new chevrons
Are we saying
... is the new rounded Citroen?
Wish they came with images! Confused.com
x 6956
Ignore what style the badges are - they are just illustrative - which numbers do you want?
X7 Badges
X7 Badges
