Hello Folks
Need some help with fault finding why my washer pump no longer works.
I've tested the pump connection to washer bottle using a known working pump.
Swapped the steering column switch for another, still nothing.
Wipers function
Fuse checked and OK
Any ideas what else to check, is there a relay hidden somewhere that could have failed?
Xantia Screen washer pump not working
- x 8462
Re: Xantia Screen washer pump not working
S1 or S2 Xantia?
I can supply wiring diagrams as I've been here before...
I very much suspect you have a break in the wiring loom between the source of power, the switch and the motor... The diagrams will assist as they also have detailed loom (harness) wiring diagrams...
Before I can supply I need to know the series and preferably the RP Number/age of the car to ensure the right ones are supplied....
jvwykes
- x 11
Hello Citroen Jim
Its a 1999 HSI SX series 2
regards
regards
- x 8462
James, I'll dig out the diagrams as soon as I can. Shame it's not an S1 as I have those immediately available but for the S2 I need to fire up the scanner...
I'll get it done as soon as I can..
- x 8462
James, here are the diagrams:
S2 Wash Wipe Circuit
S2 Wash Wipe Harnesses
S2 Wash Wipe Locations
I trust they will help solve the problem...
jvwykes
- x 11
Many thanks for your quick response. Much appreciated. Multimeter out tomorrow and when I find the problem i'll let you know
regards
regards
- x 8462
Excellent James
All the very best in finding it quickly and easily
jvwykes
- x 11
Found the root cause.
Using the diagram I thought i'd start at the pump connector once more. This time I found 12V. Must have been slight corrosion on the terminals. Plugged in my spare motor and it burst into life. The original pump however has had its day. So thankfully no major strip down to find a broken wire, just old fashioned electrical tarnish
- x 8462
James, that's excellent news
