Front Struts Creaking
hayden2004
front struts are making loads of noise and the ride is very hard and the struts creak when you get out , do you think the struts are knackered and if so are there easy to replace and can you buy recon
philhoward
hayden2004
philhoward
hayden2004
alexx
Well, I don't think that some trapped air would cause creaking, maybe some hissing or so. There is a big chance that struts are creaking. Check also roll-bar bearing and H/C linkage.
Unfortunately, I think that there are no repair kits for Xantia/XM front struts, like for BX ones (totally different construction).
You probably didn't hear this sound before because spheres were flat and front of the car didn't rise upon leaving the car.
- x 1506
I had some sucess on a BX with pulling back the strut gaiters and greasing the struts - took a few hundred miles to work its way in, repeated a couple of times. However, badly creaking struts is a sign they are knackered and should be replaced. I think they are around £100 from GSF, fitting shouldn't be too badm but I think you need a big spanner to get the nut off the top.
hayden2004
mipster
mipster
hayden2004
