Changed the wipers on kangoo the other month for its MOT,
Maybe I'm a bit dumb.
Is it possible to "park" wipers in another position apart from there normal horizontal place?
Is the driverd side only meant to lift an inch or so from the screen as changing it is proper **** about?
Kangoo Wipers (61)
demag
- x 102
Re: Kangoo Wipers (61)
Switch the wipers on then turn the ignition off when the wipers are in the vertical position. That normally does it for me.
Sent from my Wileyfox Swift using Tapatalk
Dave
