MyWay Sat nav wrong way
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
renagade
x 10
Unread post by renagade »
Hi Guy's
I have read my answer on here a month back but can't find it again now, I want my navigation arrow to point in the direction that I am going but it keeps changing although it does get me to where I want to go. My old tom tom would always point to the front of the car my MyWay points to the front then the back and then to the front again.By the way my car is a 2011 c5 1.6e-hdi +vtr egs6 if that helps. I have put the 2016 update into the head unit .
There are so many roads to travel but so little time, (Paul Cofield )
x 6947
Re: MyWay Sat nav wrong way
It's to do with your map settings, you can have it either 'North Up' or 'Heading Up'. I can't tell you how to get there as I have the Navidrive 3D, but it is in the manual. You need to have navigation showing, then usually access the shortcut menu and then map settings and it should be somewhere there to change the option.
renagade
x 10
Hi thanks for that I will give it a try next time i am in the car. Is your c5 x7 a auto or manual?????? I bet it has the fluid suspension, I had that on my old DS,CX and BX.I would say that Citroen had a world beater with that suspension.
x 6947
renagade wrote:Hi thanks for that I will give it a try next time i am in the car. Is your c5 x7 a auto or manual?????? I bet it has the fluid suspension, I had that on my old DS,CX and BX.I would say that Citroen had a world beater with that suspension.
Mine's a 6 speed manual, Exclusive and wouldn't have even considered a metallic sprung one - so haven't got a clue what I'm going to do when the Golden Hornet gives up the ghost! I've yet to see what this 'exclusive to Citroen' new suspension is going to be like and I'm not holding m breath. A win on the Lottery and I would snap up an SM tomorrow!
