Revers on Sat Nav (RT6)
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
renagade
x 10
Unread post by renagade »
2011 c5 e-hdi 1.6 egs6. Now we all know what car I drive. Do we think it is poss. to link my own reversing cam. to the myway satnav that came with the car???????
There are so many roads to travel but so little time, (Paul Cofield )
x 6960
Re: Revers on Sat Nav
Not as simple as wiring in a camera I'm afraid. Head unit needs to be able to support it and IIRC the correct parking sensor ECU.
renagade
x 10
OK,thanks I knew it would not be simple for me. It was just a thought that's all.
Homer
x 16
Unread post by Homer »
There is an aftermarket addon which plugs between the head unit and display and simply takes over the display when you put the car in reverse.
http://www.xcarlink.co.uk/product.php?p ... t=0&page=2
http://media-in-motion.co.uk/reverse-ca ... onnection/
x 6960
Yes at over £200 for one and no price on the other, and somewhere to fit the suitcase sized interface.... :rofl2:
There has been a comprehensive post about this here, were we looked at options (including the link referenced above)
https://www.frenchcarforum.co.uk/forum/ ... ing+camera
x 6960
As I said, there are certain hardware revisions of the MyWay unit and the later e-MyWay which need to have the integrated video chip inside the unit as well as the correct ECU if you are going for an OEM solution. The issue you have is output to the head unit and compatibility, so if you are really determined, then why not consider an over rear view mirror reversing camera solution that ACE did here - a much cheaper alternative and looks better, without interfering with your existing system:
Aftermarket electrochromatic rear view mirror + camera
viewtopic.php?f=3&t=52248&p=447352&hilit=camera#p447352
