Well I have another one then !
x 2006
Unread post by Stickyfinger »
2ltr Petrol Auto, 6th months MoT...Zero rust...a few scrapes and a wing is dented. Auto Box reportedly "slips into neutral", well it didn't on the drive home :)
It really does drive very well indeed.
x 3298
Re: Well I have another one then !
Methinks Alasdair is trying to breed Xantias!
x 2006
well 2 out of 3 are ####ed that is true
x 8437
Excellent :D Good to see Alasdair...
Get that ATF changed and see how it goes then...
x 2006
I take it it is a 3x drain and fill method Jim ?
Do you know the amount I will need to do the job in total ?
x 8437
Yes it is a 3 times in fairly fast succession job...
A couple of gallons should do it I reckon...
Remember it must be DEX II mineral ATF and not anything that claims to be compatible...
x 3298
Anything else should be named "bugritup fluid"
x 8437
Hell Razor5543 wrote:Anything else should be named "bugritup fluid"
:rofl2: Yes!!!!
x 2006
it takes 9 and change Ltrs of oil ??....gosh
This the stuff.....1/2 the price of the Castrol stuff ?
http://www.ebay.co.uk/itm/Granville-017 ... SwYIxX4DOE
x 8437
That looks OK Alasdair...
If that's part number 0175 then it'll be good..
Else, try this Comma one as that can be very reasonably priced too..
http://www.commaoil.com/productsguide/view/6/190/ATM5L
x 2006
Comma @ wilco....£47 and change to deliver 10 ltrs
x 8437
It's got dear.. last time I bought some, when I had an XM, it was dirt-cheap...
x 2006
reports have it a certain make of truck uses it, and up the road is a truck mechanic who "happens to have" 12ltrs in his workshop.
How much driving does it need between drains ?
x 2006
Vehicle family XANTIA
AS/RP N° 07480 CJ 1 0455
Warranty Start Date 01/01/1990
OPB DIL0
General information
PRODUCT TYPE CAR
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY XANTIA
SILHOUETTE 5 DOOR SALOON
TRIM LEVEL SELECTION PACK
ENGINE INJECTION XU10J2
TRANSMISSION BVA4
INTERIOR TRIM TYPE ALACANTARA VELVET "FV"
UPHOLSTERY COLOUR "FY"
GEARBOX (CHARACTERISTICS) BVA 4HP14
Suspension-Steering-Brakes
ABS WITH ABS BRAKES
HYDRAULIC PUMP PRESS PUMP 6+2 + NON-SINKINg
Interior fittings
elma
x 284
Unread post by elma »
Stickyfinger wrote: Warranty Start Date 01/01/1990
So it was out if warranty quite a few years before they built it, or even released the Xantia.
Only Citroen... :rofl2:
