Lexia 4 tips and tricks
DinuIoan
Unread post by DinuIoan »
What else can you do with lexia 4 - diagbox ? Without Clearing or Reading faults .
spider
x 77
Re: Lexia 4 tips and tricks
Unread post by spider »
Program new transponder keys / code remote keys (central locking) / radio (on some models) , quite a host of things such as say enabling cruise control (if its been fitted) etc , things will vary depending on what car its 'talking' to.
You *cannot* do things like odometer adjustments however for obvious reasons. The hardware is capable of it but its not in the software, the same as other 'off limits' things I won't mention...
Andy.
DinuIoan
Thanks !
x 6950
DinuIoan wrote:Thanks !
At this point, if you are new to Lexia - read the advice here:
https://www.frenchcarforum.co.uk/forum/ ... 53#p509923
The Lexia is a useful piece of equipment in the right hands; but you should also be aware that there is no 'undo' button, so be VERY careful with it as you can easily brick your car if you don't know what you are doing.
