Fault codes f701 f702
Peugeot_Russ
Unread post by Peugeot_Russ »
Hey all, so today i discovered these 2 fault codes in my 407. it cleared out for a while then reappeared. it keeps saying passenger humidity sensor fault- I took it out and cleaned it up and put it back- fault still shows up. some sort of loose wire is jingling around in the sensor itself. And i cant find any online to buy- not even used!
then for some reason the cabin temperature sensor is also acting up. is this the sensor located on the drivers wing mirror? some sources report that if that sensor goes, the temperature would show up as -- or wrong. but my read correct external temperature.
On tthe dashboard, in the middle of the console where there is some air distribution, there is a little black bubble there, i took that off but theres nothing under it or inside- its just a black plastic cap.
ANy one have ever had these issues?
demag
x 102
Re: Fault codes f701 f702
Unread post by demag »
Have you changed the pollen filter? An old one will cause humidity problems.
Sent from my Nexus 7 using Tapatalk
Dave
Peugeot_Russ
Yes. I changed that a year ago and I keep it on cabin air recycling so it doesn't force Intake of outside air.
demag
x 102
I think the temperature sensor is by the rear view mirror at the top of the windscreen if its like some Citroen's I've owned. There was a tiny little grille that would get blocked with fluff and dust.
Sent from my Wileyfox Swift using Tapatalk
Dave
Peugeot_Russ
Hello. thanks for the reply. I think that sensor you mentioned is for the rain sensor auto wipe. I have no clue where the cabin temperature sensor is. the humidity sensor is above the glove box behind the trim where there is a little grill.
