2008 Espace IV. Xenon headlight washer pump fuse and relay?
Axa
Unread post by Axa »
Where is the fuse and relay located on Espace mk4?
The pump is not running at all, and I will replace it even if it's just the fuse that is gone. I have been trough the same ordeal on our 2006 citron C5
https://frenchcarforum.com/forum/viewtopic.php?t=47266
Also any tips on how to replace the pump from below with the bumper still on would be greatly appreciated! :-)
Skickat från min XT1562 via Tapatalk
2006 C5 1.6 HDi ( vin: VF7**************[VIN obfuscated, can be read by forum staff] )
2008 Grand Espace 2.0Dci Auto
Axa
Re: 2008 Espace IV. Xenon headlight washer pump fuse and relay?
Any one that can explain where the pump is fed from so I can try to run it with a bridge from the battery?
There's no way I can manage to get the pump out without removing and bend out at least the right hand side of the bumper. So I really would like to find out if the fault is in the pump or not before I start to disasemble the front..
lexi
x 134
Unread post by lexi »
You are best to get a CD workshop manual for it. They are usually floating around on Ebay. I had one for my Vel Satis and it gave detail on about 10 different Renaults, every relay Ecu and trouble shooting. One of the best manuals I had.........all the P/Ns as well. I am sure your Espace has similar set up to Vel Satis.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
