407 TPMS there or not?
Peugeot_Russ
Unread post by Peugeot_Russ »
Hello. Does anyone else have a question about their 407 tire pressure monitoring system? I did a scan with planet and it shows no faults, which is expected since i've have never gotten any message on the dashboard- even when the pressure was drastically low due to a puncture and low again when parked for a month in storage.
under the valve measurements in the system, the pressure in each tire correlating to the valves is 0 and doesnt move. the temperature also is nil and it reads underinflated even though i just inflated them.
in the BSI available ECUs i noticed the TPMS was listed as missing- so i changed it to present. Apparently to calibrate each wheel one needs some sort of tire force tool and inflate it by 3, 7 bars. I have no idea what that is about. A general scan on the system itself declares no faults. what is going there? so is it working or not?
its expensive to change all four if it can be fixed, maybe a cleaning. The battery is still good as planet reads voltage correct on each valve sensor.
ANy thoughts?
x 3296
Re: 407 TPMS there or not?
You will need to use something called an 'exciter' (along with a 'Planet Peugeot' system) to wake the system back up. I have not done this myself, but others have.
x 1939
Unread post by Paul-R »
You probably need a TPMS exciter to stimulate the valve while the car is stationary.
I've only used a Lexia on a Citroen but I imagine that PP is similar. For the Mk1 C5 the Lexia prompts you activate the exciter next to a specific wheel in turn. The Citroen exciter is called the Protoctair, or was - I think it's been superseded. I wasn't able to obtain an exciter so I disabled the TPMS system in the BSI - which is what sounds like has been done to your car.
The Mk2 and Mk3 C5s use different systems but still need an exciter.
Peugeot_Russ
hey guys thanks for the reply. an exciter eh? where do i find one of those? I dont think the sensors are bad but its a lot of fiddling on planet to get these things to work. planet says to turn it on or off use the accessories menu which i cant find.
Peugeot_Russ
Where did you go in lexia to disable the tpms? im going to try turning it back on and see if the car can pick up the sensors. it appears to be a lot of trouble. why didnt they use something easier- like those plug n play valve sensors- ...which doesnt need a ECU to read or detect.
Peugeot_Russ
The last owner used to try hard with car- im thinking there must be a reason he deactivated the TPMS . If the system is too sensitive and beeps low pressure every trip then it is in no way worth the effort getting restored. Once rented a S class- drove 400 miles over a month. No warning until about the 255 mile mark
x 1939
The reason I deactivated the system was that one of the valves needed re-pairing - the other three were OK. I found it very annoying to have the warning beep every time I started the engine up. It was doubly annoying as I'd just bought a brand new valve and I didn't know about the special exciter tool needed at the time. I'd have saved some money and gone straight to turn them off if I had known.
Sorry, can't help with where the TPMS is on the PP as I've never used PP, only Lexia.
Peugeot_Russ
I have no clue as to where this exciter force tool is or how it looks. I see some stuff like autel https://www.amazon.com/Autel-TS401-Maxi ... 7SR20EQD88
without it, i have no way of fixing the sensors to read the pressure- new tires, rims are due. dont want to change that without dropping some new sensors as well.
furriegurrie
x 40
Unread post by furriegurrie »
I just had my tpms activated and paired to the C6. Had it done at Euromaster. Cost me 40 euro. Tried before with the official Citroën dealer tool but failed. This was most likely to do wth the fact that my sensors were purchased through Ebay and are officially for Jaguar/LandRover.
Took them about 5 minutes and a short drive to do it. They used an Ateq VT56 device.
407 might be similar, can't hurt to give them a call....
Peugeot_Russ
I see. I think i solved my TPMS problem- replace the old Peugeot one with a set of new modern TPMS system- there is some really good after marketing ones out there that give- based on product description- better results If its true, then its incalculably more efficient, reliable and user-friendly than the stock OEM one. I think that the better option all round to go since restoring the OEM one would be very problematic where i live, and doubly expensive. Plus it would be good to keep an eye on a visual reading of the tires on a screen rather than hooking up a diagnostic.
Peugeot_Russ
I managed to reactivate the sensors- it keep reading fault code C1604 something about left tire sensor aerial something. the fault can be cleared but i havent tried it to see if it will reappear. the system can read the bars and temperature from that sensor so i assume the sensor is working.
If i change all sensors to brand new ones, will it need reinitialization? or will it be plug n play?
Peugeot_Russ
I managed to reactivate the TPMS sensors. I had to put about 3.8 bars of pressure in one problematic tire to get the System to pick up the reading. After a quick drive the system was reading all the sensors. Its a shame the system cannot give you real time pressure on each 4 sensors instead of relaying a message only when the pressure drops on any one or more of the tires. Will keep it active until the TPMS replacement unit comes- then i;ll replace the entire thing with a real time monitoring system.
