The seal carrier was a toast, 75% of it rusted so I pulled it off and ground the rust as best as I could and slapped on a couple of coats of POR-15. In the long and fine tradition of this particular GSA, I'll leave the next owners to find out the real horror when they pull it down again
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Questions: What is the best way to adjust sunroof in relation to the cutout? There are three allen head screws on each side sunroof rail and the problem I found is it's nigh impossible to adjust the rear most screws because the sunroof aft edge is not running on the rails so I can't apply force via sunroof panel with it partially open or closed (which seems the only situation where I can access the rear most screws). With the sunroof fully open, I can push up the rails via the sunroof handle but I can't seem to access the screws to fix the position.
