hi to all
have just noticed that i am losing coolant but can not see any leaks from anywere and oil leval is fine so not the HG
can anyone help.
cheers edd
losing coolant
philhoward
Just because the oil is fine doesn't mean that the head gasket is fine...
Could be a number of things; leaking radiator/expansion cap, even cracked/porous head!
You could have a fine split somewhere such that it only leaks when hot; by the time it's all cooled down the leak has evaporated!
How much coolant are you losing? A litre per week, or a cupful a month?
edd001
AndersDK
Edd -
The most sure indication of a leaking HG is air bubbles from the coolant filler - cap off - while engine is idle. More bubbles as you rev the engine. Test from cold - and do it for peace in mind.
The coolant filler neck should always have some 10cm of free air left - to allow for fluid expansion when hot.
1L in 3 weeks sounds to me like a leaking hose - look for white deposits at every coolant hose stud - and over the radiator body. Very rare you'll actually see a dripping leak - as the cooling system is pressurised with hot engine - and then any leaking fluid evapourises fast. Som smallish steam from engine bay with hot engine after a drive is usually a telltale.
monkeyman
edd001
Richard Gallagher
Ohh err Ed, I'd better not pass comment on your wifes attributes! Seriously though when I had the matrix go on the Xantia estate I could only smell it briefly after about 5 minutes running. I presume after then I just got used to it, however the real tell tale sign was a damp carpet in the front passenger footwell and a tendency for the windows to steam up when the air con wasn't on.
edd001
arry_b
You can spend many hours tracking coolant loss. Have a garage pressure test it and look for the leak / bubbles when the system is under pressure when cold. The kit to do it is like a bicycle hand pump with piping etc to connect it to the radiator.
My tame garage did it on my wife's old cavalier and didn't charge.
