Wiring
C3 vts
Wiring
Unread post by C3 vts »
Any1 on here know any one that can do some wiring changes. I've put a c2 vts engine in my 1.4 c3 and need plugs altered so engine loom and engine fuse box plug into the c3 chassis loom and also 1 plug altered on chassis loom so it plugs into c2 ecu.(2 fit 1 doest)
x 6945
Re: Wiring
Be aware that your C3 BSI won't be configured for the C2 Engine and components. I assume you know about matched engine ECU, BSI and transponder chips in the Keys?
C3 vts
Re: Wiring
Yea know about ecu and transponder chip. What's BSI
x 3296
Re: Wiring
Body Control Unit (but I would guess that BSI stands for it in French).
C3 vts
Re: Wiring
Plan is to use the c2 engine loom and ecu and alter plugs so connects to the c3 chassis loom. Then tape c2 key to the barrel of c3
x 1055
Re: Wiring
Unread post by wheeler »
BSI stands for Built in Systems Interface 8-)
C3 vts wrote:Plan is to use the c2 engine loom and ecu and alter plugs so connects to the c3 chassis loom. Then tape c2 key to the barrel of c3
That wont work unless you also have the BSI from the donor car. The ECU, BSI & transponder chip are all a matched set, if one of them is different the car wont start.
Apart from that it shouldn't be too difficult a task as the C2 & C3 are practically identical electrically. I would imagine the BSI would be a straight swap.
x 1940
Re: Wiring
Unread post by Paul-R »
wheeler wrote:BSI stands for Built in Systems Interface 8-)
That's the usual British use but I'm sure I've read here that in French it stands for Boite Systeme Integrale (there's a bunch of accents as well - sorry) which literally stands for Integrated System Box. All much of a muchness really.
x 6945
Re: Wiring
I think it is actually 'Boitier de Servitude Intelligent' Paul.
x 1940
Re: Wiring
Not heard of that one Marc. I was just passing something I'd seen.
x 6945
Re: Wiring
I could be mistaken Paul, but it seems in common use on some French sites. :wink:
C3 vts
Re: Wiring
has anyone got or know where i can get wiring diagrams for c2 vts and c3 1.4 and also information on what ecu pin does what
x 6945
Re: Wiring
Have you seen whether the Haynes manuals for the C2 / C3 have what you need? They do have some wiring diagrams in them. Quite cheap on the bay at about £11-12
http://www.ebay.co.uk/sch/i.html?_from= ... l&_sacat=0
C3 vts
Re: Wiring
yea got c3 and c2 haynes manuals but no ecu information
x 6945
Re: Wiring
All the wires are coded. The colours are irrelevant and mean nothing, and the pin layouts have been known to differ vehicle to vehicle, but the codes printed on the wires tell you what they are. If you compare the wiring identifier codes from the same ECU plugs on the donor cars that should be enough to match them to the correct positions on the new car
I've listed a lot of the wiring and component codes on our Wiki here:
https://www.frenchcarforum.co.uk/wiki/E ... ring_Codes
