I have not via a bit of tracing hacked up a couple of resistors (0.25w 3.3ohm) one to each side of a squib, one to the driver under seat and at first one to the passenger side under seat..
restarted the vehicle and for about two whole minutes no airbag warning light at all and I thought I was saved and had at least found the correct wires and the main fault.. (I was going to move on to a permentant repair tomorrow)
But then I restarted the vehicle a few times and after about three or so minutes it does infact turn on the airbag light once more, just really slows it down.. Si I thought to add another resistor to the passenger side(two inside the same plug) and now it's not showing at all..
BUT... when their is one resistor in the passenger and the airbag light does go out for two mins the dash is fine and only handbrake showing, then the airbag pops back..
THEN.. When putting two resistors under the passenger and turning over the engine the sirbag light never comes back on but the SRS?? (seatbelt lights never go off even if I plug both of the belts in...
So I'm really lost now and must find the seatbelt wires and do something with them of the same I think..
One fixed job is leading to another now and this is getting beyond the normal eh, hehh
