My 2.0HDi auto Exclusive made an odd noise today! I was setting off from a standstill at a busy junction, accelerated sharply, and as the revs built up (presumably in 1st gear) there was a very obvious noise, just for a second, that sounded as if a valve of some sort was 'blowing off', if that makes sense. It has done it once before, similar circumstances, around 2/3 months ago.
Any ideas? It sounded horrible!
Pete
'09 C5 odd noise!
- milleplod
- My Cars: 2009 Citroen C5 2.0HDi Exclusive Tourer
(Previously, in order....Dyane, 2CV6 x 3, Visa 1.7D, GSA estate, GS Pallas, CX TurboII, Picasso...all fondly remembered!). - x 15
'09 C5 odd noise!
Nocto Diuque Venamur.
- old'uns
- My Cars: '02 C5 - gone
'09 X7 - gone
CMax - X7 replacement - gone
Acadiane - lost to a V5c applicant
'06 C5 VTR auto est
'90 Honda Beat
'73 ST70 Dax
'75 ST Dax - 120 powered - x 127
Re: '09 C5 odd noise!
If it sounded like a lollipop stick on a bicycle wheel then yes mine used to do that as well..?
i always thought it was a UJ TBH but at each service nothing to show what it was.
Got rid of mine before i got to the bottom of it
- milleplod
I racked my brains trying to think of something it sounded like.....yep, that was it exactly!old'uns wrote:If it sounded like a lollipop stick on a bicycle wheel then yes mine used to do that as well..?
Pete
- petef
- My Cars: DS DS5, C4 Coupe, DS23 Pallas, Xantia Activa
- x 11
Mine does it too. Think it is common with 2litre hdi's. I remember it being discussed at some length in the Citroenian if not here as well. Seems to be some kind of pre-ignition which makes the engine momentarily sound like a bag of nails but doesn't seem to do any long term harm, although I stand to be corrected.
- milleplod
Ooh er...that sounds worryingly serious!! I've got to say though that I didn't get the impression it was coming from the engine itself (he says, hopefully....!), more like something low down....but I know pinpointing noise is a very inexact science at the best of times!petef wrote:Mine does it too. Think it is common with 2litre hdi's. I remember it being discussed at some length in the Citroenian if not here as well. Seems to be some kind of pre-ignition which makes the engine momentarily sound like a bag of nails but doesn't seem to do any long term harm, although I stand to be corrected.
Pete
I have similar occasionally but seem to have tracked mine to harmonic vibration of one of the engine covers. (it disappears for a while if I knock and shuffle things but then returns after a while. I found if I tried a fast pull off in first gear on an empty road I could get the noise and by maintaining the revs the period of the noise could be extended. slightly oddly, I only got the noise when pulling off on a slight up-grade not on a level or down-hill so only certain junctions.
Current: C5 X7 Exclusive 2.0 HDI Manual (2008)
C3 Puretech 1.2 Feel (2017)
Previous: Citroen C5 mk1 2.0 HDI,
Peugeots 407, 406, 406,205,309, 306 Meridian, 306 L, Peugeot 207L 1.4 manual (2003)
- milleplod
The two times mine's done it were both on slight up-gradients, so that's interesting! I'll have a root around under the bonnet. Thanks!Filberton wrote:I have similar occasionally but seem to have tracked mine to harmonic vibration of one of the engine covers. (it disappears for a while if I knock and shuffle things but then returns after a while. I found if I tried a fast pull off in first gear on an empty road I could get the noise and by maintaining the revs the period of the noise could be extended. slightly oddly, I only got the noise when pulling off on a slight up-grade not on a level or down-hill so only certain junctions.
Pete
- white exec
Engine/exhaust/something touching body/something else when torque is momentarily high - eg when pulling away uphill, and engine goes through its torque curve? Engine mounting will be flexible, and torque will peak and then back off. Maybe.
Or a belt "thrash" at a certain engine revs. More easily pinned down.
Or maybe hydraulic tappet racket that comes and then goes? Had this (Toyota D4D) when engine oil grade is too thin.
- milleplod
Hmmmm.....food for thought. What about a pulley rattling?......when the aircon is on, there's a definite noise that sounds like a worn bearing or something. Tbh, its not doing it often enough to worry me....but then there's always the concern that its going to lead to something worse!
Thanks.
Pete
Thanks.
Pete
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5646
Ditto Pete - on a steep hill or sharp incline I get the vibration - took a Citroen technician out once for a spin to see if he could pinpoint the noise - and said it's likely to be some protection or shielding vibrating occasionally - doesn't do it often so I can live with it.milleplod wrote:The two times mine's done it were both on slight up-gradients, so that's interesting! I'll have a root around under the bonnet. Thanks!Filberton wrote:I have similar occasionally but seem to have tracked mine to harmonic vibration of one of the engine covers. (it disappears for a while if I knock and shuffle things but then returns after a while. I found if I tried a fast pull off in first gear on an empty road I could get the noise and by maintaining the revs the period of the noise could be extended. slightly oddly, I only got the noise when pulling off on a slight up-grade not on a level or down-hill so only certain junctions.
Pete
