So, best get it replaced I suppose, bit of a fag not having a handbrake all winter! Anyone done one? Doesn't appear too bad....
307 Handbrake cable
- x 1489
307 Handbrake cable
Note to self - when you think a hand brake cable needs replacing because it's likely to freeze up, then replace the damn thing. Otherwise you find yourself in the drive at 7am and -4°C with your head torch on thawing out the cable with a hairdryer so you can go to work
jgra1
- (Donor 2021)
- x 36
Re: 307 Handbrake cable
sorry Richard you have all my sympathies
but..no not done one !
this winter is feeling tricky already and it's not even December yet !
john
edit. obvs don't use the handbrake overnight again for now
- x 1489
New cable arrived ... it appears to have tubes a la the C5, but as they are under the car, I'm hoping the cable will come out the tube, not a la the C5!
Mandrake
- x 695
Sorry to hear about the handbrake cable Richard - haven't heard of them freezing in cold weather before!
-4 degrees this morning at ours too but the car started like a champ as the battery was replaced only a year ago. I'm probably tempting fate a little though because I haven't done the infamous Xantia V6 starter helper relay mod yet!
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
- x 1489
Job done; it's not that hard once you realise the joint between the cable and the tube is at the back of the fuel tank, not right under the car. Obviously this is only after you have drifted the end of the tube out of the car above the exhaust, and are then fighting with it wondering how the hell you are going to get the old cable out that appears to have gone really stiff!!
