Citroen Picasso, Starting issues
imperial21
Unread post by imperial21 »
Hi
my step daughter Picasso is struggling to start in the morning, i went and got her a battery for it, once i found it i see a nice new looking battery, i swapped it over anyway in case and took the old one to be tested, It was tested and found to be perect !! :oops:
She says its very slow turning over (even in the summer quite slow), really struggling in the mornings once started ok , i am going to guess that its the starter motor ? its an ex taxi done 230k miles.
Is it on the front of the engine ? i had a feeling its at the back and a pig to get at but i hope i am wrong !
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
mickeymoon
Re: Citroen Picasso, Starting issues
Unread post by mickeymoon »
If it's a 90bhp HDi it's at the front of the engine and pretty easy to get to. Best from below, with a helper above.
imperial21
Hi thanks i am not sure if its a 90bhp or 110 ! fingers crossed its a 90
x 3300
Well, I have a 110HP C5, and the starter motor is also down at the front. I had to replace mine, and I got a reconditioned one from GSF for around £120, but I also got around £55 back when I returned my old motor in the packaging provided.
imperial21
Thanks i think its a 90bhp, hopefully it is the starter motor and all will be happy !
Richard_C
(Donor 2026)
x 224
Unread post by Richard_C »
With any slow cranking issue its worth checking the earth return side of the wiring (assuming you have checked things like the battery terminals and the +ve to the starter). I'm not sure about the Picasso, but a lot of cars have the earth from the engine block, battery and other things all going to a bolt on the bodywork. I bit of corrosion and it offers resistance to high current on starting. Undo + a good clean can help.
Richard_C
x 1929
Unread post by Paul-R »
Not just the earth return. The standard overcentre terminal clamps have a habit of losing their strength of grip. Cutting them off and replacing them with proper bolt and nut clamps can sometimes sort a problem out.
