Hi all can someone inform me how to remove these tubes & how much trouble are they to do.
What's involved in this task as the manual doesn't seem to say anything about this you're help would be very informative thanks.
A only need to remove these as to clean & grease them & replace them.
Cheers graeme
Hand brake cable tubes
Taximan
Citroen c5 2.0 HDI
Year 05
Vin no : VF7**************[VIN obfuscated, can be read by forum staff] 76601045
Year 05
411514
- (Donor 2017)
- x 39
Re: Hand brake cable tubes
Hi Graeme
I swapped my guide tubes relatively recently and they were not overly difficult to remove. A little fiddly though. I seem to remember that the left was easier to remove than the right. After much wiggling I undid the joint between the exhaust manifold and mid-section pipe to gain an extra few inches of wiggle room and this made things much easier. In short then, not difficult, and certainly do-able, but fiddly.
Unless I misunderstand your post, it seems that you are planning to simply change the handbrake cables and reuse the guide tubes. I suggest that this is a little optimistic. It seems to be the case that the heat from the exhaust pipe causes the cable outer to melt and weld itself to the inner surface of the tube, meaning that it is near impossible to remove the cable from the tube. It seems to be pretty well established then that you need to change the guide tubes as well as the cables, which is what I did, meaning that the old guide tubes are effectively scrap (which makes removal easier).
However, if you grease the cable outer when inserting the new cables into the new guides, it might be the case that next time you come to change the cables they will be removable from the guide. I did this and will report back in due course when I next change the cables.
Sam
Sam
Sam
2003 C5 2.0HDI 110
2003 C5 2.0HDI 110
