Help
My central locking remote has gone dead on my Xantia, tried new batteries, the fuse and cleaning both the plip and receiver, any suggestions anyone.
I would not be to bothered but the drivers door does not lock with the key.
Central lockimg blip
AndersDK
xantaxi
Russell
When you say, "does not work", does does a key in the driver lock try to lock then the solenoids bounce it to unlock again, or is the lock mechanically broken.? Or something else.?
Anyway the plip not working could be
a) Plip broken
b) reciever broken
c) no power at reciever or problem due to corrosion.
I think that some people have reported water damage to the reciever if the rooflight leaks, could be difficult to spot.
C is my favourite as it's the cheapest and easiest.
Try firing the plip at a camcorder, you may be able to see the IR.
Or if you have a meter, you may be able to detect the Plip at some of the reciever connections.
best of luck
Russell [;)]
a) Plip broken
b) reciever broken
best of luck
Russell [;)]
xantaxi
The key just turns round and round in the lock i think it is knackered (like the rest of the car ) I just tried the blip in a digital cam it does not seem to work.
Is this a reliable test, I also fired the TV remote and could clearly see it light on the camera screen. but only the red light on the plippin plip.
Thanks guys
Thanks guys
Homer
- x 16
Nikolaymk
davey
xantaxi, you should see the ir from the plip as russel pointed out on the camcorder - using the tv remote proves your camera can pick up ir ok.
i've repaired many of these plips in the past: they take a hammering in every day use and often suffer 'shock' damage, the most common fault ive found is dry (mechanically & electrically bad) solder joints that secure the ir led in the plip to the small cct board - very carefully (the board and components can easily be heat damaged) resolder them and try again ...
enjoy
enjoy
blueboy2001
