Still haven't got this C5 going and she's just a week away from being scrapped. I am sad about that but I really can't afford to have the big beast sitting rotting on the driveway. If she doesn't go, she's away. I have a lexia now and am slowly trying to learn how to make best use of it. The car comes up with the one consistent fault, that the Eolys fluid is below minimum. Does this immobilise the car? Everything else, the temporary faults, clear but this doesn't. Now, I filled the Eolys tank a while ago but was unable to get the car to recognise this so as far as the ECU is concerned it has squirted all of its fluid into the fuel tank. If this is an immobilising situation how can I get the ECU to recognise an Eolys fill, because it's still practically full, if I can't run the engine and this is, I believe, part of the resetting the level process. As ever, all help most gratefully received.
Tom
C5 2.2 HDi 2003 Eolys Additive Reset Help Needed
xantom
- x 3
Tom
1998 Xantia Mk2 1.9TD Saloon
1996 Xantia 1.9TD Estate Mk1
(Previously Old Guy's)
- x 6955
Re: C5 2.2 HDi Immobiliser ECU - Where is it?
Tom, as this question is really a completely different issue, I have split it into a new Topic and renamed it to something more relevant to resetting the additive. Hopefully this will get people looking at it who may be able to help - as the old topic is really to do with your immobiliser issues etc
wurlycorner
- x 271
Re: C5 2.2 HDi 2003 Eolys Additive Reset Help Needed
I believe you have to tell the car (via lexia) that you have refilled the eolys fluid - it doesn't recognise itself.
Have you explored all the settings for that?
Iain
CX DTR T2 Safari (silver)
Iain
