Citroen synergie
HugoMcN
Citroen synergie
Unread post by HugoMcN »
Please help I have a 2001 synergie but there is no handbook in it .... the cigarette lighter fuse blew ... but don't know what fuse to change or if it's the one under the bonnet or behind the dash on the passenger side .... tks in advance
x 6945
Re: Citroen synergie
Have a look at this thread, a few posts down:
https://www.frenchcarforum.co.uk/forum/ ... hp?t=10328
Richard_C
(Donor 2026)
x 234
Unread post by Richard_C »
Mine was older but based on a 98 model:
Likely to be in the fusebox behind the glovebox (ease the side tabs in, drop box down and out, remove panel behind)
From memory it will be #16 or thereabouts, which has 2 positions, a 2 tab fuse with 3 slots so it can go left or right pair. In one of them the cig lighter socket is on only with ignition, in the other its always on - useful when camping or to trickle charge through rear socket.
Rear and front lighter were on same circuit, I used to leave the rear one out because if you load the boot you can and up pushing and holding it in - bad!
Richard_C
BX
x 19
Unread post by BX »
Yes it's in the fusebox behind the glovebox. The fuse can be inserted in either of two positions. The cigarette lighter can either be permanently live or controlled by the accessories position on the ignition switch. I should have the handbook for this model. If I find it I can scan whatever pages you need.
HugoMcN
No I don't have the hand book lads that's my problem I don't know which one to change and don't want to start Pilling fuses out
x 6945
Did you click the link I gave you? They're all listed there.
