egs6 clutch
renagade
- x 10
egs6 clutch
i have a lexia how do I set the clutch on a c5 x7 citroen with the egs6 gear box????
There are so many roads to travel but so little time, (Paul Cofield )
- x 1485
Re: egs6 clutch
What are you trying to do?
You can bleed the clutch if the slave cylinder has been replaced, and then you can re-program the gearbox actuator. I think if you just want to set/adjust the biting point, then you just take it and accelerate hard from a standstill a few times.
Edit: See the reply from Lighty in https://www.frenchcarforum.co.uk/forum/ ... hp?t=54343
