Gears crunching
Kym1
Gears crunching
Unread post by Kym1 »
Hi all, I have a Citroen Dispatch van 2007 but unfortunately 1st and 2nd gears crunch when they go in unless I'm extremely careful and slow. Is this a common fault? Can I overcome the problem without spending too much?
Kym
x 1751
Re: Gears crunching
Check the clutch pedal height is properly adjusted, and no excessive mats etc. under the pedal.
Check also the oil in the gearbox is correct type and grade - in cold weather, too heavy an oil can make gear engagement and changes difficult/baulky.
Kym1
Re: Gears crunching
Cheers Chris, good advice. I will check this out but I fear the problem might be a little more mechanical :?
x 7163
Re: Gears crunching
Kym1....
A warm welcome to the FCF, and your vital statistics are extremely interesting!
A DB6 on your car list, and much more important than that a location of Norwich, Norfolk!
Now you may ask why? Well at the start of the summer, I started this thread
The FCF AA Box Challenge 2016
There are now only 19 AA Roadside Boxes across the country, with 11 remaining to be "claimed" with a genuine original photo, all the better if it includes a nice shot of the car as well! and yes one of them is in Norfolk at Brancaster!
Norfolk
Box Number 530 Brancaster, Norfolk: on A149 (Hunstanton-Wells) around 300 metres west of junction with Common Lane, Brancaster Staithe
We've even delved into an interesting thread "What do you know about Norfolk?" in a thinly-veiled attempt to get FCF members from Norfolk to join in with the AA Box spotting obsession!
Its quite a good read if you have five minutes!
https://www.frenchcarforum.co.uk/forum/ ... =2&t=55825
