C5 autobox fluid change method.
milleplod
x 15
Unread post by milleplod »
I've Googled and searched on here, but not found anything specific. I'm going to change the autobox fluid using the '3 litres at a time' method. Is it as simple as opening a drain plug, which will release 3 litres, then topping up with the same amount via the level-check/dipstick tube? Or is it more complex than that...?! :?
Pete
Nocto Diuque Venamur.
Mandrake
x 694
Re: C5 autobox fluid change method.
Unread post by Mandrake »
It would be very helpful to know what model of C5 it is (what engine etc) so we can figure out what gearbox it is as they all have their own procedures ;)
On early C5 AL4 and 4HP20 were typically used depending engine. On late C5 some other gearboxes were used.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
milleplod
x 15
Sorry, I mentioned it in my gearbox post yesterday but forgot this time! :oops:
'09 plate C5 2.0HDi Exclusive with the Aisin AM6 box. :)
Pete
