Lifts
superloopy
x 19
Lifts
Unread post by superloopy »
I'm thinking of adding a new garage extension early next year so a bit of forward planning is due now before we get down to plans etc ...
Does anyone own a scissor lift as i'm thinking of fitting a concealed lift to the garage, which, although on the smallish side at 14' x 16', will serve as my work area for one car only at a time.
And, i've ALWAYS wanted a lift of some sort :) . Currently got a set of four hydraulic ramps which do the jobs ok'ish but only when the weather permits so the garage will be a big bonus!
just need to know of any pitfalls (no pun intended :-D ) of such a venture regarding the lift, the garage is a no-brainer, dead space on the side of the house which just goes green without any sun hitting it up here, being based North East coast :wink:
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
x 1750
Re: Lifts
If building from scratch, then a pit could be a possibility.
Only problem with a pit, is that if you move house . . .
On the other hand, it scores rather well on the safety stakes.
x 2943
Re: Lifts
The biggest pitfall is the bloody minded councillors and planning enforcement fascists and of course nightmare neighbours.
I managed for twenty years with a pit and jacking beam but if you're doing a pit you need to really work out how to seal it against the water table, mine needed to be pumped out regularly despite the guy who built it lining the hole with polythene before pouring the concrete.
KennyW
x 163
Re: Lifts
Unread post by KennyW »
Why not build the garage around your 4 pillar lift !!!!!!!!!!!!!!
Only joking I agree extremely useful, Pit with scissors jack would be my favoured option but waterproofing is the issued mentioned by gibbo.
Kenny
C3 1.4 petrol (SWMBO)
x 1750
Re: Lifts
Waterproofing (tanking) is really easily achieved in this part of the world by simply coating the concrete/masonry structure with what, here, is called caucho or antigotteras. It's actually a thick latex enhanced water-soluble emulsion paint, that can be applied by brush or roller, and up to a thickness of several mm. For creating a waterproof membrane under outdoor tiling (for example a flat, tiled roof terrace), a coat or two are laid down, followed by one layer of good old coarse glassfibre mat, and then topped with a couple more coats of caucho.
The result is a glassfibre-reinforced impermeable membrane, tough and flexible, that cement, concrete and further construction will adhere to. It's also used, without the glassfibre, under terracotta roof tiles, which become water-laden in heavy rain.
It's available in white, terracotta, blue (for pools and reservoirs), green and grey. In white, it can be used to paint the surround to a swimming pool, where it provides a satin, non-slip, jet-washable and UV-proof finish.
Fabulous stuff, which I had never encountered in the UK. And, no, I'm not on commission; my salesman days are over.
lexi
x 134
Re: Lifts
Unread post by lexi »
Probably SBR based. Styrene Butadiene Resin. There is another resin called Flexacryl or Acripol. They can be put on top of glass mesh or painted on thick.
I think the Spanish stuff may be based on similar chemicals? Sika also make liquids to add to mortar to coat concrete or brick for tanking. A butyl or EPDM liner can also be used, much better than polythene. It can be welded to make a bag. Casting a GRP bathtub insert is most expensive of the lot.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Richard_C
(Donor 2026)
x 202
Re: Lifts
Unread post by Richard_C »
I thought one issue with pits was potential for the build up of fumes and vapours, particularly heaver than air petrol vapour, with people overcome by fumes or even worse self-immolated. I wonder if house insurers would cover a claim if a fire from an amateur pit spread to the house? Sorry to be pessimistic, I would love a pit but maybe ramps/lifts as the OP suggested are a safer if less convenient way to do it. Some cheery tales:
http://www.hse.gov.uk/mvr/topics/fire.htm
http://www.mirror.co.uk/news/uk-news/vi ... ee-2661989
http://www.theiet.org/forums/forum/mess ... adid=35718
Richard_C
superloopy
x 19
Re: Lifts
Richard ... you're right here. I am not wanting any inspection pit or such like. What i am after is an "inground' lift, i've seen a scissor lift at my local garage. Just asking if anyone had any experience or advice to offer. Seems the discussion went its own way in my absence [emoji3]
Sent from my LG-D855 using Tapatalk
Mike
HDI
x 7
Re: Lifts
Unread post by HDI »
I've worked with a few scissor lifts and they are quite good, definitely better than a pit! Obviously a 2 post lift is better but they require much more space and height clearance. The scissor lifts I've used lift on the sills and raise about 1.5 mtrs, so you will need a good seat to work underneath the car, unless you are very short, or you can used a crawler, which works well because the working height can be adjusted to suit any task. For working on wheels, brakes etc they are great!
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 2943
Re: Lifts
Richard_C wrote:I thought one issue with pits was potential for the build up of fumes and vapours, particularly heaver than air petrol vapour, with people overcome by fumes or even worse self-immolated. I wonder if house insurers would cover a claim if a fire from an amateur pit spread to the house? Sorry to be pessimistic, I would love a pit but maybe ramps/lifts as the OP suggested are a safer if less convenient way to do it. Some cheery tales:
One of our local mechanics had all his skin burned of in such an incident, they had drained a petrol tank over the pit spilling some in the process, then struck up a welding torch .whoosh.
