Suspension fluid
Taximan
Suspension fluid
Unread post by Taximan »
Can you see the fluid in the bottle easily or not because a have looked at mine and a can't see a thing.
When a take the cap off there's fluid in there but don't no if it needs topped up or not because a can't see any fluid in the bottle what so ever thanks
Sent from my iPhone using Tapatalk
Citroen c5 2.0 HDI
Year 05
Vin no : VF7**************[VIN obfuscated, can be read by forum staff] 76601045
x 3296
Re: Suspension fluid
To check the LDS fluid levels you need to bottom out the suspension first. Then, when you take the cap off the reservoir, you will see a series of vertical slots in a basket like affair. These slots have two heights, and the LDS should bet between the lower and upper slots.
x 6945
Taximan
Thanks al check that tomorrow.
This might sound daft but do a need the engine running when a check the fluid
Citroen c5 2.0 HDI
Year 05
x 6945
No, just put suspension to lowest setting and wait until it lowers. You can switch off and check levels then.
Taximan
Citroen c5 2.0 HDI
Year 05
