Clio noisy from cold
OmLebz
Unread post by OmLebz »
Good evening I'm new here,anyway this my last throw of the dice. The engine had a bad ticking rattling noise from the cylinder head. The noise was apparent from start up,all the way through the revs. It was the same hot pr cold. So I changed the cambelt,tensioner,roller, waterpump and vvt pulley all brand new. Fitted new hydraulic liftera as well. Problem now is the engine still has the tapping noise? initially from start up then it kinda quites down abit as it idle. As aoon as u rev it up the noise gets louder, all the way through the revs,sounds as if something might come through the tappet cover. Any ideas to a solution would be gratefully appreciated,thank u.
Reason: Split from Laguna thread
x 5674
Re: Clio noisy from cold
Welcome OmLebz. :welc:
I have taken the liberty of splitting your post from the original thread into a thread of it's own to avoid confusion.
Hope this meets with your approval and you receive some answers soon.
x 1470
Unread post by xantia_v6 »
For the avoidance of confusion, can you be more specific about which type of engine your car has?
OmLebz
Evening, tnx steve. its the 1.6 16v engine clio 3. Its raining outside will post engine code when it subsides abit.
