1.6 HDI Glow Plug operation?
uncle buck
x 10
Unread post by uncle buck »
I'm interested to find out what controls the 3 minute post starting heat cycle on this engine, does anyone know?
Starting the engine from cold (12 degrees C) :
when you turn the ignition on there is no glow plug pre heat operation, but once the engine is started the plugs come on and stay on for 3 minutes, this is obviously a timed period but what controls this time period, is there a timer relay somewhere ?
If the engine is warm there is no 3 minute post heat cycle, I assume this is signalled by the coolant temperature sensor?
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
x 1480
Re: 1.6 HDI Glow Plug operation?
I imagine it's all controlled by the engine ECU.
uncle buck
x 10
Yeah it probably is ECU controlled these days.
I was interested as I fancied experimenting with the 3 minute post heat cycle which would have been easy if the time was controlled via a timer relay.
Cheers.
