Help!!! Please
Bradb
Help!!! Please
Unread post by Bradb »
Hi please can any one help !! I have a Peugeot 308 sport 1.6 turbo which I have recently had a new master cylinder fitted and since then after repeatedly bleeding the system every time I press the brake with pressure the abs and esp light comes on and cuts my brake lights out! I have changed the brake light switch but still happens! Went to a garage to get it diagnosed and the port isn't working but fuses are all ok! Also the daylight running lights ((side lights) don't come on like they use to before I'm am at my wits end now and no one seems to be able to help please can any one on here help!!!
x 1055
Re: Help!!! Please
Unread post by wheeler »
Was the system bled properly using planet/diagbox or other suitable diagnostic equipment ?
BX
x 19
Re: Help!!! Please
Unread post by BX »
It needs to be bled using a diagnostic tool to activate the ABS pump. Many diagnostic tools have the brake bleed function.
