Any suggestions on how to change these once the ball joint starts to rotate in the cup. Mine are coming to the end of thier life yet again, also the poor condition of the roads in rural northumberland are not helping.
I have considered using bolt croppers, could this be possible?
Many thanks
306 Anti roll bar drop links
VisaGTi16v
so when you try and turn the nut the whole thing spins so you cant undo it? If you kinda force back the rubber cover on the other side you can get some thin pliers/mole grips in and if you hold them damm tight you should be able to undo the nut. May be an idea to keep spraying them with wd40 for a few days before attempting to undo them to loosen them up
kevin
Yes I have tried the WD40 trick with the mole grips. Even tried soaking the offending item in diesel and parafin and still they spin.
The diesel and parafin is a great trick for un-seizing metal items. The next ones to go on, I will file with a grinder two flat sections so to improve the grip of the spanner, mole grips etc when they fail again.
- x 1490
mgoodlad
kevin
