c5 suspension
mm1
c5 suspension
Unread post by mm1 »
Hi all.just noticed today that a little oil is dripping from near the sphere at the back wheel on the driver side.any idea of what it could be.please tell me its not a big job.thanks in advance.
wurlycorner
x 272
Re: c5 suspension
Unread post by wurlycorner »
Could be a number of things. You'll need to narrow down the source more closely.
Assuming it's from the suspension cylinder unit rather than anywhere else, some possibles;
- Rubber boot at the bottom of the cylinder holed/split or one of the breather pipes (that poke into it) come loose/not fitted properly (none of which are big jobs - see my c5 profile thread for info on changing the boots)
- High pressure pipe corroded/leaking/seal perished
- Sphere loose (unlikely) or seal between the sphere and cylinder perished
Iain
CX DTR T2 Safari (silver)
mm1
Re: c5 suspension
Thanks for the reply.the oil seems to be coming out from around the wide end of the boot but the boot does not seem to be damaged.the two pipes and sphere seem to be grand.i presume the boot is meant to seal up where it is joined on.
wurlycorner
x 272
Re: c5 suspension
The boot is meant to seal, yes.
There is a metal spring clip that goes round to hold it tight. Is that fitted?
As I said, pics and details of how to change it are in my C5 profile thread.
Pic of a (new) boot with the clip correctly in place below;
Iain
mm1
Re: c5 suspension
Yes the clip is fine.i removed it today and cleaned all around it.then refitted.(not bloody easy)i thought maybe some dirt got in there.but i was wrong.it was still the same after.
wurlycorner
x 272
Re: c5 suspension
How much fluid was inside the boot when you pulled it off?
There shouldn't be much there at all (literally a few dribbles and that's it).
Iain
mm1
Re: c5 suspension
There was very little.as you said,just a few dribbles.
dnsey
x 19
Re: c5 suspension
Unread post by dnsey »
The breather connected to the boot and running up into the crossmember can sometimes dribble a little fluid , which then runs down the tube and onto the boot.
wurlycorner
x 272
Re: c5 suspension
If there's no fluid inside the boot, then it's difficult to see that would be causing a visible leak on the outside, without any obvious hole in it. :-k
8-[ Absolutely sure that it is suspension fluid that's leaking?
Iain
mm1
Re: c5 suspension
The breather pipes seem bone dry.it just off the bottom of the wide end of the boot that the drop is coming from.is there something else that could be leaking there lain
wurlycorner
x 272
Re: c5 suspension
I was wondering about fuel tank/filler? Thats roughly above there IIRC???
Iain
mm1
Re: c5 suspension
Have been looking again this evening.there was a drop of fluid hanging from the boot.so dried everything up and got my mrs to raise and lower the car as i kept and eye on it.as the car went up towards the top it leaked some fluid again and it definetly came from the inside the boot.could there be an invisible hole in the bloody thing or could there be some dirt gone in round the boot.
wurlycorner
x 272
Re: c5 suspension
Ok well its good to have confirmed the source. Just change the boot if you're concerned - they're very cheap from Citroen (something around a fiver, IIRC).
Iain
mm1
Re: c5 suspension
Do you think a boot will sort it or will it need new seals also.AFAIK the car got new boots a few months ago.
wurlycorner
x 272
Re: c5 suspension
It's difficult to know - if the seals were gone, I would have expected the boot to be full of fluid?
Iain
