Damper Seal Kit
Cfiver
Damper Seal Kit
Unread post by Cfiver »
Does anyone know where I can get a rear damper piston seal kit for a 2004 C5 2.2 hdi ? My local main dealer tells me that Citroen don't supply them.
x 1438
Re: Damper Seal Kit
Unread post by xantia_v6 »
Cfiver wrote:Does anyone know where I can get a rear damper piston seal kit for a 2004 C5 2.2 hdi ? My local main dealer tells me that Citroen don't supply them.
Are you sure that you need one? what are the symptoms?
x 1929
Re: Damper Seal Kit
Unread post by Paul-R »
IIRC there is no kit, you have to buy each seal separately. When I say separately, in practice there is a pack size which contains a minimum quantity. Again IIRC I think one was packed in twos and another in fives but I could be mistaken.
They were all still available from the dealers when I enquired a couple of years ago. For what they were they weren't particularly cheap though.
lexi
x 134
Re: Damper Seal Kit
Unread post by lexi »
Try one of the dealers on Ebay like Louth. Some dealers have packets open and will sell you singly.
Be careful you haven't just jacked the car while not on high. That can cause a leak from dampers if fluid is high.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Cfiver
Re: Damper Seal Kit
Thanks to all for the replies. Symptoms are rear offside gaiter full of fluid and car sits lower on this corner.
Cfiver
Re: Damper Seal Kit
Cfiver
Re: Damper Seal Kit
lexi wrote:Try one of the dealers on Ebay like Louth. Some dealers have packets open and will sell you singly.
Do you have more details about the Ebay dealer 'Louth'? I have searched for this without success.
Cfiver
Re: Damper Seal Kit
No problems....just found them. LCS Louth. they seem to be very well stocked for Citroen parts
x 1480
Re: Damper Seal Kit
3 seals in the rear ram:
Part Number Description Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000527228 RING-SEAL 1.32 GBP 1.58 GBP 1.58 GBP
0000527230 SLIDING SEAL 3.45 GBP 4.14 GBP 4.14 GBP
0000527232 WEATHERSTRIP 2.08 GBP 2.50 GBP 2.50 GBP
