Alarm fuse?
superloopy
- x 19
Alarm fuse?
Anyone know which is the alarm fuse on a 1996 S1 Xantia? Just hooked a battery up to my longstanding activa to see whats what. Plip not being recognised, alarm going crazy (!!) and depressing the switch in cabin does nothing. Bu@@er!!!
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
chinkostu
- x 30
Re: Alarm fuse?
Bit late but f15 i think it is! Haven't got the handbook near!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
harryp
- x 75
Re: Alarm fuse?
Insert key into ign and turn should switch alarm off IIRC??
Regards, Harry
2000 Nov Forte HDI 110 hatch in Wicked Red; currently SORN
2000 Mar Exclusive HDI hatch in Quartz; currently SORN
2013 C4 Picasso Excl E
Peugeot 207cc 1.6 Roland Garros
chinkostu
- x 30
Re: Alarm fuse?
S1 doesn't unfortunately!
2 secs i'll type the alarm reset procedure up
You can also try holding the sensor override button down while turning the ignition, it should flash the indicators. Otherwise
Alarm reset (from what i can remember)
Take both battery terminals off. The alarm should go ballistic. Put the key in the ignition and turn to position 2. Go back and put the positive terminal back on, and then the negative. Run back and hold the alarm override button down.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 3298
Re: Alarm fuse?
There goes that alarm!;
Reason: Fixed YouTube link.
superloopy
- x 19
Re: Alarm fuse?
[emoji1][emoji1][emoji1]... very good. I eventually pulled F17 and she went silent allowing me to try and resync the plip but its not having any of it. Need to dig up the resync for an IR plip but i thought it was as simple as key to position 2 and fire plip a good few times towards roof sensor? Obviously not. Plip IS firing ok, checked with camera. New batteries inserted still no go. Any ideas? I can assume pulling F17 has nowt to do with this, yes?
Mike
Re: Alarm fuse?
Are you sure it's not the alarm doing what it should, i.e. telling you a door. bonnet, boot etc. is sensed as open.
chinkostu
- x 30
Re: Alarm fuse?
Nah the alarm shouldn't affect the central locking. I find it can be a ballache resyncing IR remotes, I unlocked the car turned key to 2, pointed at the reciever and pressed the first button (raised one) a few times, then ignition off and leave it for a minute before testing. Mine (when syncing a second remote) had original remote only, none working, new one only, deadlock and alarm button on new one but lock unlock on original and then finally both working. It's like rolling the dice and took me hours to get working properly.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
superloopy
- x 19
Re: Alarm fuse?
Spent a good while on this and still no show [emoji22]
Mike
chinkostu
- x 30
Re: Alarm fuse?
is there any way of checking the roof sensor works?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 1746
Re: Alarm fuse?
Does your Owner's Handbook detail the alarm reset procedure, assuming it's OE equipment?
During the '90s, Citroen were fittimg a variety of alarm systems, all slightly different. On the XM, by 1996 remotes had become RF, although the roof-mounted IR bulge was retained, giving the impression that the system was IR! Confusing.
A check on Service.Citroen under vehicle Characteristics should specify which system you car was fitted with.
chinkostu
- x 30
Re: Alarm fuse?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
chinkostu
- x 30
Re: Alarm fuse?
As far as I know the RF plips didn't come into use until the S2 Xantia, although I stand to be corrected!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 1504
Re: Alarm fuse?
Correct: IR on MK1 RF on MK2.
You should be able to cancel the alarm by locking the car, then unlocking it, and within 10s opening the door and turning the ign on whilst holding down the alarm cancel / internal sensors defeat button. In theory pulling the alarm fuse shouldn't shut up the siren, as it has its own internal power supply (although this may long since have died). Early MK1s also had a silence key switch under the bonnet. This doesn't stop the headlights flashing, but it should stop the siren deafening you.
chinkostu
- x 30
Re: Alarm fuse?
or in my case completely kills the alarmRichardW wrote: Early MK1s also had a silence key switch under the bonnet. This doesn't stop the headlights flashing, but it should stop the siren deafening you.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
