renault trafic quickshift
pete260
Hi all new to the forum,hoping somebody can help i have a renault trafic 2.5 dci 2006 with quick shift auto,i have air in the clutch hydraulics can any body explain the best way to bleed,i have been told its best to back bleed from the slave cylinder but i am having problems with the bleed nipple it does not seem to unscrew like most i am used to.Thanks Pete
demag
- x 102
Re: renault trafic quickshift
Hi Pete only just seen this.
I had a Fiat Multipla that had a strange bleed nipple on the clutch. It actually had a small circlip that had to be pulled out slightly to release the nipple. The nipple didn't screw, it slid in and out and had an o ring round it.
Sent from my Wileyfox Swift using Tapatalk
Dave
pete260
Hi Dave,Thanks for your reply, i had a better look at it over the weekend and you are right it looks like a circlip,its just in quite an awkward place and my eye sight is not what it used to be,i shall now have a go at back bleeding.Regards Pete
demag
- x 102
It's been years since I owned the Fiat Pete. If I recall there's nothing to stop the nipple flying out once you release the circlip but I think there was a second circlip slot in the bleed position. So you pull the circlip slightly, ease the nipple out until you can slide the circlip back in to hold it. It was awkward on the fiat so don't know how the Reno will be.
Dave
