Pug Quick Connectors
Peter D
Quick fit Pug connectors To remove the connectors used on vacuum and fuel pipes on Pug 106 Look 2’s, you need to spray them with WD40 then squeeze the single black button which is part of the more rounded end of the connector and where used it is the side away from the 90 degree elbow. Later models and 206 series on use two coloured buttons are much clearer to see. Peter
