Clearing eolys nag
wirdip
Clearing eolys nag
Unread post by wirdip »
Hi guys, have had diesel additive low on screen, have had 2 ltrs pat fluid put in tank, will Lexis clear ecu and stop message, if so what is best version to use on 2004 C8 2.0 hdi executive. Have got spare laptop just need advice before buying. Live in Walsall West Midlands anyone local who could show me the ropes or clear nag.
Regards Alan
x 3301
Re: Clearing eolys nag
If you are buying it for yourself to use a lot, get the Easy Diagnostics kit. It is reliable and current. If you are going to help people with certain PSA vans you will want the version with the extra module (about £150 in total), otherwise go for the normal kit (about £110). If you mention that you are a member of the forum they may not charge P&P.
However, if you only need it to clear the Eolys message, you might want to look on the list of members with Lexia kit who are willing to help out. Here is the link;
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178
x 6955
wirdip wrote:Hi guys, have had diesel additive low on screen, have had 2 ltrs pat fluid put in tank, will Lexis clear ecu and stop message, if so what is best version to use on 2004 C8 2.0 hdi executive. Have got spare laptop just need advice before buying. Live in Walsall West Midlands anyone local who could show me the ropes or clear nag.Regards Alan
Yes the Lexia will clear the message - you will need to tell it how much has been added and it should do the rest. As James says, Easy Diagnostics are the most reliable ones and have the full chip hardware, plus the support if needed. They're currently sold out again as of this post, but that's because they sell so many!
wirdip
Thanks for info guys will try to get software as advised
Regards Alan
