I am get rid of Citroen C5 2.0HDI 110 for Peugeot 406 2.0HDI 110, I am still struggle to find 406 with ESP & cruise control. Is this were standard or on a option?
which range model is like to have this system? GLX, S, SE or Rapier?
Buy used 406
- x 1995
fv43576
- x 3
Re: Buy used 406
Ok cruise control retro so that is no problem now, what about ESP which range is possible have them on?
spider
- x 77
Re: Buy used 406
Later models had optional cruise from GLX spec up (so this was not far off the 'base' model) I remember a regular customer had a 2.0 with Cruise and that was otherwise not a 'high spec' model at all.
I'm not sure on ESP. Do you actually 'need' it ? The car is quite stable generally and sensibly thought out suspension, offering good grip and half decent in bad weather too. I do not recall traction control being available, it may of been on the V6 units however.
All (or almost all) late models as in 2000 onwards will have ABS with that EBFD 'addon' anyway. This is really just a way of not having a 'rear compensation' valve though.
Andy.
fv43576
- x 3
Re: Buy used 406
Thanks Spider for advice, I think I better forget about ESP.
- x 1489
Re: Buy used 406
Currently only 76 on Autotrader, and of those only 1 has ESP - and it's a coupe. I think if you want a 406, then you'll just have to buy what's available! If you really want ESP then go for something later. The MK2 307 for instance has ESP on SE and above.
fv43576
- x 3
Re: Buy used 406
Not interest in other car, I like the 406 is good enough I will buy one day when I find good one.
