the issue is that my fans don't turn on at all, it the set up with the two fans on the front (with air-con). I have three relays on the front that all work (all brand new and tested), both fans work fine (tested) and the bitron module (again replaced and i think it is working OK).
When I unplug the brown temp sensor on the thermostat hosing the feed to the bitron unit goes open loop and the fans go on full speed. when i turn the aircon on the fans go at half speed (as they should i believe they should) so this makes me think the bitron is working and the fans and relays all works as i get full and half speed working well.
the only thing that is left over is the brown temp sensor now. i make some leads up with some small spade connectors and checked the temp sensor from pin 7 and pin 14 of the bitron module interface (these are the pin that go to the sensor) and at cold i seem to get about 2.2k?. at 24c and then 2.7k? at 100c. I thought this might be wrong so i ordered a new one.
The new one has come and i tested it in boiling water before i installed it into the car and the new results i am getting are pretty much the same as the results of the one fitted to the car! So is this right or do i have two duds?
What kind of result should i get out of a brown Peugeot temp plug? I thought this was the kind of result range i was meant to expect maybe this is for a green plug.
WARNING after looking around I found this is not the correct data sheet for the brown bitron sensor
I know this set up is the same in allot of cars like the 405, 306, 206, xantia's and others. Mine is a 1995 petrol 405! I would be very very grateful for some help!
I am starting to this i should get a POT (0? to 5k?) just to test when the fans come on!
