Help please
RPWC
- x 21
Help please
MY Dispatch 1.9 has suddenly become flat,will not pull past 50mph, drop a gear and floor the throttle, it starts hunting, black smoke coming from exhaust, local garage diagnostic machine came up with these two faults PO112 and PO102, I disconnected the MAF, but it made no difference. The machine says these codes are related to the MAF, is this correct and should I consider buying a new MAF?
Cheers Rich
RPWC
- x 21
Re: Help please
Disconnecting MAF , no difference, tried a different one from a friend's van, still no different, so obviously not that, but why is it in limp mode?
Cheers Rich
- x 6950
Re: Help please
Have you checked the air intake hoses from the filter assembly to the throttle body? If there's a leak and air is entering the engine without the ECU knowing about it, then it could give a false MAF fault. Check the wiring on the plug to the MAF - and the pins are all clean and making contact. If the MAF and more importantly the sensor wires are contaminated with muck, this will cause hesitation and stalling Rich.
RPWC
- x 21
Re: Help please
Done all that Marc, I put new rad in at weekend, and had air filter off a couple of times, but it has been fine since, until today. The heater hose hadn't been secured properly and was seeping this morning, rectified that and checked tonight to see if I had broken a wire, as there;s a sensor next to it, but no, all intact. Its not cutting out, just won't go over 30in first and second,40 in third and 50 in 4th and 5th. starts as normal ticks over as normal, cevs ok when stationary
Cheers Rich
- x 1061
Re: Help please
Assiming its a DW8 engine Theres a vaccum operated butterfly in the inlet manifold that can stick & cause problems that would be my first port of call then next would be looking at the EGR valve as both of theese things can log MAF faults.
RPWC
- x 21
Re: Help please
I have tested the butterfly and its free, have sprayed half a can of e g r cleaner in it too, tried brand new MAF today and no different, getting a new fuel filter tomorrow,as the garage that serviced it in August, are helping me out. They mentioned that they'd had trouble with Crossland fuel filters, so are going to change it for me tomorrow .
If that doesn't work, then it will need further investigation. I thinking will book in with the Citroen dealer, as they have the machine that will interrogate the E C U . The local garage can only take it so far. They have tested it again with the diagnostic tool and it went clear the faults listed MAF and air intake temp sensor.
Cheers Rich
Re: Help please
Have you checked the vacuum hoses that connect to the EGR, turbo actuator and butterfly valve?
RPWC
- x 21
RPWC
- x 21
Re: Help please
Had it up to here now!! I've had 4 years almost trouble free motoring from this van, but this has finally turned me. After the problem is fixed, its going, and I will not be buying Citroen again. Going for something easier to work on, that doesn't have about 10 different parts available for the same vehicle.
Enough is enough, I am eternally grateful for the help and advice I have received from you all on here, but I just cant take any more hassle.
All the time the van is out of order its costing me a lot of money in down time from work, and as a self employed sole trader, time is money.
Need something I can just drive, rather than have to spend every weekend underneath it.
Cheers Rich
- x 6950
Re: Help please
Really sorry to hear that Rich - but time is money as you say and it's not as if it's a hobby or a labour of love! Best of luck with whatever you end up getting.
RPWC
- x 21
Re: Help please
Marc, thank you,and for all your, and everyone else's help during my time on here
I have read the same statement many times on the Rover75 forum, and tried to help and advise newbies who were thinking of quitting.
Difference is the car isn't what makes their living :
I will certainly recommend this forum to others with French vehicles. I already did on the Rover forum, someone was considering buying a C5 ,wondering whether it would be as good as his Rover, so I pointed him in this direction.
Cheers Rich
- x 1504
Re: Help please
Sorry to hear that - but it must be over 10 years old and xxx miles to be a 1.9D. Anything newer will cost a lot more in initial purchase - and they are getting more complex to work on, with 'parts' (mostly sub assemblies with ECUs!) getting ever more expensive. I see the need to have it on the road if it means business though. The only way, perhaps, to guarantee trouble free is to go to a new one on a PCP deal to keep the monthly cost down. You've got to get it main dealer serviced then though - and it still might go wrong and be off the road!
elma
- x 284
Re: Help please
Have you checked the accelerator cable? A lot of xuds have a black plastic cylinder halfway along the cable. It is spring loaded to stop anything being stretched too much when you floor it. The spring loses tension over the years and then the throttle won't open on the pedal.
elma
- x 284
Re: Help please
I'd also be inclined to check the leak off pipes and around the fuel filter housing for seeping diesel.
RPWC
- x 21
Re: Help please
Looks like the cat is bunged up, the garage suggested disconnecting the cat and see if it makes any difference, so I did and it felt like it was pulling better.
Re connected it ,took it out again and there was definitely resistance,I'm going to repeat the test over the weekend and make sure Im not just imagining it.
Cheers Rich
