workshop manual
RPWC
x 21
workshop manual
Unread post by RPWC »
Why is it there was never a worship manual published for the mk1 Dispatch/Scudo?Expert?
Every other vehicle has a manual ,except for this, the mk2 has one ,but cant get one for the mk1 for love nor money.
I have tried Amazon,Ebay and all the usual outlets but none to be had.I even emailed Haynes direct to ask,and they said there was never one published. Is there anything available online to download? My car has a manual called Rave. which is available as a cd rom, but I use a Mac, so don't have a disc drive of any sort. Proir to buying this van, I had a Berlingo 1.9d with the same engine ,the 1868 version of the XUD? so I kept the manual for that, as some things are similar, typically the cooling system is different, so couldn't refer to it when changing the rad today.
Cheers Rich :wink:
Richard_C
(Donor 2026)
x 233
Re: workshop manual
Unread post by Richard_C »
There is a series of French workshop manuals, nowhere near as user friendly as Haynes but with some useful stuff, all in French but you can usually work it out with the help of google translate. I got one for my Synergie soon after I bought it, 1998 and refer to it occasionally. In those days it was in a bookshop in France but now you can go online. It assumes some general mechanical skills and pre knowledge.
Can be ordered as paper or downloaded. You might find something to help.
http://www.revue-technique-auto.fr/
I think it might have been a Jumpy in France
( a CD rom drive for your Mac so you can read the one you have might cost you less!)
Richard_C
x 6945
Re: workshop manual
There is a place that does them for the Expert - but it's in French - Revue Technique - I've used them myself. You have to select Peugeot as the marque and then there are quite a few listed for each Expert Model. Couldn't see any listed for the Dispatch though under Citroen.
They are are well-illustrated with photo's. There is a money-back guarantee and the manuals are 29.50 euros for the Paper Based (Papier) PDF or the Digital (numérique) is 24.90 Euros. If you go with the on-line digital version, then you always have an up to date version and can use Google Translate or similar as you view the page. One word of warning though - although you can download or print pages of your manual to PDF - they will plaster your email multiple times as a watermark over every page. This is to disuade people from copying / distributing their copyrighted work. If you are interested, here's the link - google translate the page if you need to - it's quite easy to navigate the site.
http://www.revue-technique-auto.fr/trou ... nique-auto#
Edit: Richard and I were obviously typing a response about the same place at the same time! :-D
RPWC
x 21
Re: workshop manual
Thanks Gents,will have a look.
Cheers Rich :wink:
