Is there anyone rebuilding Xantia suspension struts?
My left hand front is showing a bit of oil on the outside, and I reckon this is a precursor to a leak
Xantia suspension unit
- x 8309
Re: Xantia suspension unit
Dave,
No, sadly, the Xantia front struts are seen as being irreparable. I believe the last to be refurbishable were BX ones...
Martin at Pleiades may be able to offer more information but generally they last very well and you should be OK finding a replacement from a scrapper...
davewithington
Funny thing is the left front was starting to leak on my white VSX, at a similar mileage
- x 8309
Must be some special killer potholes up your way Dave...
Mandrake
- x 694
Are you sure its leaking ? Where is the oil appearing ?
If it appears to be leaking where the shaft goes in at the top, it's more likely that the leak is one of the o-rings in the strut top where the top of the shaft attaches - the oil will run down the shaft and pool on the top of the strut.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
aerodynamica
- x 215
Wouldn't simply be a leak from the old strut return pipes? I had to replace mine recently due to a little split in the old ones, but my it leaked an alarming amount!
Graeme M
davewithington
No, I replaced the returns with new boots when I bought the car four years ago. It's only misting on the outside as yet but I much prefer planned maintenance to firefighting
I'll have a look at the strut top O ring, I have a couple of new tops in my garage
c.morewood
- x 55
Let me know if you need a strut..there are two where the hook came from.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
c.morewood
- x 55
No its a w 1.8 petrol.. But aren't all the front struts the same?
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
- x 8309
To all intents and purposes yes, barring V6 and Activa...c.morewood wrote:No its a w 1.8 petrol.. But aren't all the front struts the same?
davewithington
That's interesting Jim, I've seen the odd new unit about with non VSX specific part numbers.
I'd prefer to fit new if I can, there's no rush
- x 8309
I don't doubt there's small differences warranting a different part number but to be honest Dave, I think, under the circumstances, any differences are going to be so minor you won't even notice...
Note that V6 ones are a bigger diameter... You could use them but you'd need the matching strut tops too...
c.morewood
- x 55
I'm sure they'll be there for a while dave. Out of interest its one of those with the c5 fittings.
'94 Fiat TipoTd 40K
'94 Fiat TipoTd 40K
