Citroen C4 - Hard braking pedal on startup
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
Car is Citroen a petrol C4 1.6 with auto gearbox ( AL4)
Some updates to the following thread
http://www.frenchcarforum.co.uk/forum/v ... =3&t=55836
I noticed that after the car has sat for couple of hours on startup ( after turning the engine on ) the brake pedal is hard when engaging the gear to Drive. On the N position the brake pedal is OK. Before engaging to Drive I pressed and depressed the brake pedal couple of times , but the hard brake is there when engaging the Drive. The brake pedal is back to normal ( almost ) after driving for a couple of meters ( around 10 meters ).
If I tried to get on a high ( 20 cm ) pavement carb the car fails to do it and the pedal brake becomes rock hard.
Referring to my previous thread , the garage suggested to replace all of the valves hydraulic lifters , but I don't think it will help.
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
(Donor 2022)
x 8
Re: Citroen C4 - Hard braking pedal on startup
Any help ?
