What size Nuts
Billathome65
What size Nuts
Unread post by Billathome65 »
OK guys
Ive got the stuff needed to replace the CAT on my 2002 C3 as the nuts are under the flange of the manifold to CAT it's a little tricky trying to decide the size of socket needed to remove the nuts are they 13mm or something else as the 13mm seems a little sloppy also planning ahead what size bolts would be needed should I need to drill out the stubs?
Cheers guys.
chinkostu
x 30
Re: What size Nuts
Unread post by chinkostu »
Pretty sure they should be 13mm. A massive extension on a rachet is a given!! I'd go out with a handful of sockets though.
I'll see if servicebox lists the studs too.
Edit: Studs are M8x125 :)
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 1939
Re: What size Nuts
Unread post by Paul-R »
If 13mm is a bit loose then try a 1/2" socket (12.7mm). And if that's too loose then try a 12mm socket.
Sockets should also be single hex; bi-hex (12 point) are too prone to slipping and rounding the nut.
chinkostu
x 30
Re: What size Nuts
Use loads of plusgas too!
Agree on the hex, it's easier to find a bi-hex but also easier to round!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
Billathome65
Re: What size Nuts
Cheers guys for the info
